AVS › AVS Forum › Video Components › Home Theater Computers › New TV broke GOM player
post #1 of 2
Any ideas on how buying a new TV would cause a specific player to stop playing well. It use to play perfectly smooth, but now i get stuttering on DVD files. The same files play perfect in windows media player.
Llano A6 with win7 64bit
post #2 of 2
Check your TV for how you should be connecting it - some are picky about which is to be used for a PC vs commercial player. Also, check your PC settings -- assure you're still on 60Hz... it could be the EDID of the TV told your PC to use 50Hz... I use the A6-3500 in my bedroom just fine!
