AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › How many buttkickers do I need for a sectional
post #1 of 2
I am looking to have a media room in my basement and thinking about putting an L shaped sectional (probably one of the palliser models). If I do this and want to install buttkicker LFEs, is there some rule of thumb for how many I need?) Do I need one per piece of the sectional or if they are all connected will they rumble together.
Also, If I install the buttkicker on convertible bed part of sectional will this cause metallic rattling from the folded bedframe (not sure if anyone has done this but figured it's worth a shot).
post #2 of 2
I use one LFE unit with each separate piece of my sectional (2). I would advise attaching the units directly to the frame of the couch if at all possible.
Not sure about the bed frame but I think it would rattle.
