Originally Posted by 808///M3
Which electrical parameters - of power amps - would one have to consider when connecting a 105 directly to them?
- Input impedance; is there a minimum? Is higher always better? I understand the 105's output impedance is 100 Ohms.
- dB gain?
- Input sensitivity?
- How much different are the above between the XLR and RCA outputs?
The reason I ask is:
- I want to know what electrical parameters will give the best range of levels (from barely audible, to louder-than-needed), without sacrificing dynamics or an inaudible noise floor.
- I've read that even when the 105 is at volume level "1," some say their system plays too loud.
- I want to know, will you lose dynamic range when reducing levels digitally? For example, will there still be 24 bits of dynamic range at volume level 1-10?
- It seems gain controls on each channel could be mandatory for some power amps - mainly to reduce the gain. How much adjustability is needed?
Sorry for cross-posting, but there are at least 2 threads on this specific subject.
- dB gain?
See the following technical note posted by OPPO UK on this:
http://www.oppo-bluray.co.uk/UserFiles/Docs/PDF/BDP-105EU%20Direct%20Power%20Amplifier%20Connection%20V2.pdf
The range of Volume control on the 105 is set so that precision is maintained even at low Volume settings, which is why the Volume control doesn't go all the way down to -90dB or some such. If I recall correctly, they've got it set at 0.5dB per step, so -50dB at Volume 1. Volume 0 is implemented as Mute.
Note that the XLR outputs are the standard +6dB hotter than the RCA outputs.
--Bob
