AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Oppo BDP-105 "Sound Quality" Check Thread for Audiophiles
Featured Stories
Topics Discussed
Related Forum Threads
- Disappointed in the Oppo BD-105 Last post on 4/12/13 at 11:38pm in Blu-ray Players
- OPPO BDP-105: how to convert Apple Lossless to a FLAC data base of music on external hard drives? Last post on 4/15/13 at 3:06pm in Blu-ray Players
- Official OPPO BDP-103/BDP-105 Anticipation Thread Last post on 5/16/13 at 11:42am in Blu-ray Players
- Oppo BDP-105 Last post on 5/2/13 at 3:07pm in Audio Gear
- Oppo BDP-105 SABRE32 DAC vs Denon 4520 built-in via Airplay Last post on 4/30/13 at 2:34pm in Receivers, Amps, and Processors
Related Reviews
Oppo BDP-105 "Sound Quality" Check Thread for Audiophiles - Page 12
post #331 of 672
3/11/13 at 7:09pm
Gear mentioned in this thread:
post #332 of 672
3/11/13 at 7:39pm
- wse
- Trader Feedback: +1
- offline
- 2,760 Posts. Joined 3/2008
- Select All Posts By This User
post #333 of 672
3/11/13 at 7:48pm
- jima4a
- Trader Feedback: 0
- offline
- 801 Posts. Joined 6/2011
I would ask on the regular 103 or 105 threads. Basically if you want to use analog out (XLR stereo or multi) or feed direct from computer via USB, then 105, otherwise 103. I wish I had gone 105. As you said recently, it is expensive to upgrade- just go for the quality.
post #334 of 672
3/11/13 at 7:51pm
- wse
- offline
Just wondering, yes I am going for the 105 :)
post #335 of 672
3/11/13 at 8:33pm
- Pokey77
- offline
- 49 Posts. Joined 12/2012
post #336 of 672
3/11/13 at 8:38pm
- wse
- offline
post #337 of 672
3/12/13 at 12:33am
- bobpaule
- Trader Feedback: +3
- offline
- 1,203 Posts. Joined 7/2003
Fellas, the Oppo utilizes 2 x 24 bit DACs doing quad duty each.
The A1UDCI, and its D&M Holdings clones, the UD9004 (add shielded everything, copper chassis), and the MVP881 (glass front plate with buttons out of a 1950ies horror movie) carry 6x 32 bit AKM4399 chips, for SACD MCH you have x3 (2 channels per each), for SACD Stereo you get one dedicated DAC with fully balanced pathway, the last DAC does HDMI duty.
Show me a HT processor or receiver that has the processing power of the AKM chips, oh well Theta or Classe, but 6-10k, when you can spend a third of that for an A1 these days.
In other words what matters is one step DSD conversion, and then true transmission of the analog signal, preferably balanced. I treated my room ceiling and walls with fiberglass 2" panels, replacing the dropped ceiling tiles with DYIHometheater 24x24" and the wall with Dow-Corning 703 24x48" and the thick carpet over concrete floors made an amazing impact. Burlap sticks well to those with 3M 77.
By all means XT32 everything enjoying your receiver or processor's every imaginable combo of signal processing and reincoding if that suits you. Unfortunately for me 6 pairs of 0.5m King Cobras and a pair of XLRs with no processing except volume control will cut the mustard. It is because of the A1 that my SACD collection is now close to 500 titles. For everything else there is a PS3/Harmony adapter to create the ultimate 3D player/streamer.
And remember, all 10k SACD players before the A1UDCI mostly did 2 channel (yes, Esoterics feature AKM DACs too), while some of the very expensive MCH players are Oppo knockoffs, no fresh Ayre there:) After all design and components can be very expensive, unless you sponsor a halo product.
Let's hear it from the Jonestown gang:) Flamesuit on!
Edited by bobpaule - 3/12/13 at 12:45am
post #338 of 672
3/12/13 at 4:01am
- wmcclain
- Bill McClain
- online
- 13,985 Posts. Joined 5/2006
post #339 of 672
3/12/13 at 5:46am
It can also be used as a DAC when using an attached hard drive or thumb drive or playing off the network - so it's really not all that limited.
post #340 of 672
3/12/13 at 7:38am
- wse
- offline
post #341 of 672
3/12/13 at 7:54am
- gsr
- Oppo Beta Group
- offline
- 6,542 Posts. Joined 4/2001
post #342 of 672
3/12/13 at 7:57am
- gsr
- Oppo Beta Group
- offline
There's a list of differences in Bill's FAQ. But basically, the 105 has more inputs (coax and toslink SPDIF, and Async USB) than the 103, the headphone jack, and has better analog outputs.
post #343 of 672
3/12/13 at 7:58am
There seems to be some debate about the relative merits of different chips and I lack the technical background to sort it all out. What is one step DSD conversion (and does the terminology imply that there is some sort of dreaded two step conversion?)
I do understand that the DAC chip is just one part of the equation, which is why Oppo continues to modify its designs and why additional modifications can help quite a lot. (Don't Ayre and Theta use the same platform and chip set that is in the Oppo?) And one nice feature of the Oppo is that you can use the balanced outputs for FL and FR in a multichannel setup. The Marantz (and the Denon?) does not allow this. The Marantz also has numerous ergonomic problems (the interminable load times for Blu Ray among them.)
Last but not least, I know what my ears tell me. I know that time plays tricks on one's perceptions so I won't swear to it; perhaps I am just drinking the Kool Aid
But my modded 105 seems to be as warm and engaging, yet still just as detailed, as the UD9004, perhaps even better. And the 105 plays all discs flawlessly, zooms as needed to fill my screen, does not occasionally confuse 2ch and MCH playback, does not occasionally boost the rear speaker volumes without warning. With comparable audio quality and hands down superior ergonomics, the 105 is a clear winner in my book.Okay, give me that Kool Aid!
post #344 of 672
3/12/13 at 9:35am
hi guys...the oppo 105 thread is so informative and still learning , i just hooked up oppo 105 with my old Technics SU-G95 Amp and external Equalizer also.The speakers are Technics Full range,my setup right now is 2.1 with HSU VTF-15H subwoofer, the main speakers set as small and the sound is so wonderful and i am enjoying.Now i need little help,is LFE connection is good or i can connect my sub with other terminals.will appreciate ...
post #345 of 672
3/12/13 at 10:29am
- Kris Deering
- Trader Feedback: +8
- Avid HD Watcher
- offline
- 5,997 Posts. Joined 10/2002
The Oppo uses 2 of the SABRE32 8-channel DACs, one for the multi-channel output and one for the dedicated stereo and headphone outputs. Each set can be run fully differential and the Oppo has a fully differential balanced output for stereo playback. The AKM has a dynamic range of 123 dB in stereo mode, the Sabre is 133 dB. Both are 32 bit resolution. The Denon is an outstanding player for sound but doesn't offer near the features of the Oppo for playback and its usability is cumbersome and slow.
Edited by Kris Deering - 3/12/13 at 12:31pm
post #346 of 672
3/12/13 at 1:23pm
- bobpaule
- offline
I know, has to do with in player versus outboard DSD processing.
Thanks for claryfying that, I never auditioned a 105.
Good to know, i was mistaken on the DAC, my bad.
post #347 of 672
3/12/13 at 5:51pm
- wse
- offline
post #348 of 672
3/13/13 at 6:51am
- ufokillerz
- Trader Feedback: +11
- Troll
- offline
- 1,276 Posts. Joined 9/2003
some people swear by it, but some say that because the volume control loses bits when used
found this post made last week that seems to say it works great though
http://www.audiocircle.com/index.php?topic=114588.0
post #349 of 672
3/13/13 at 12:09pm
Originally Posted by googly moogly
Could a kind 105 owner help me out regarding 2 channel CD playback. Basically I would like to know your experience of how the Oppo compared to your stand alone CD player?
I have a Cyrus CD8x which I really like the sound off (after careful cable and power matching) but I can't have both. Has the updated power supply of the 105 rectified the bright sound during cd playback which was reported previously by owners of 95?
What did you end up doing? I am in the same position with the CD 8x and am curious how you found the 105?
post #350 of 672
3/14/13 at 12:41am
- dbphd
- offline
- 216 Posts. Joined 12/2006
wse,
When I replaced my Proceed PAV/PDSD to get HDMI connectivity and lossless processing, the local audio shop told me the SSP 800 was the logical choice to preserve audio quality. I bought a used Cary 11a instead, because I got such a great deal. Turns out I use analog from the 105 with the inputs of the Cary set to bypass, and the 105 provides lossless processing. I use the Cary for input from a phono stage and Sony XA-5400ES, otherwise I'd try 105 analog direct to the amps. I've never heard an Classe SSP 800, but the sound is said to be excellent.
db
db
post #351 of 672
3/14/13 at 9:15am
- Sharp1080
- offline
- 1,427 Posts. Joined 8/2000
I really think you'll like the BDP-105 thru the SSP-800, especially when you play your Blu Ray discs. Prometheus was the disc that made me realize how subtle yet detailed sounds in movies can enhance the performance.
post #352 of 672
3/14/13 at 11:06am
- Pokey77
- offline
Prometheus was also the disc I first demo'd my 105 with. It has phenomanal picture- and sound-quality. It showed me just how good the 105 really is. I'm lovin' the 105 every night now. It is an awesome player for a reasonable price.
post #353 of 672
3/14/13 at 12:27pm
- wse
- offline
I will try the 105 with Skyfall, just got it from Netflix today, Oppo should arrive today!
post #354 of 672
3/14/13 at 2:19pm
Skyfall's soundtrack was lackluster compared to Prometheus. The big crash sequence is pure audio and visual enjoyment. Make sure to crank up the subs at that point. That was the most gut wrenching (no joke) bass I ever experienced in my life
post #355 of 672
3/14/13 at 2:41pm
- Brian-HD
- offline
- 2,137 Posts. Joined 1/2008
post #356 of 672
3/14/13 at 2:51pm
post #357 of 672
3/14/13 at 4:45pm
- Torqdog
- Audio Junkie
- offline
- 954 Posts. Joined 5/2010
I have both Skyfall and Prometheus and if I had to pick one, I'd go with Prometheus. The first ten minutes of that movie are what I'm talkin about........good LFE, music score and directional surround. They both have good soundtracks but Prometheus is reference quality, IMHO
If I were wse and had my new 105 which replaced my 95, I think for the sake of comparison I'd want to play something I'm familiar with that I had heard numerous times on the 95.
post #358 of 672
3/14/13 at 10:12pm
- wse
- offline
I agree I love the Prometheus movie last time I watched it shook the walls.
I think first I might listen to this Audio Bliss :)
http://www.2l.no/pages/album/090.html
- DTS HD MA 192kHz/24 bit 5.1
- DTS HD MA 96kHz/24 bit 7.1
- Auro-3D 96kHz/24 bit 9.1
- LPCM 192kHz/24 bit STEREO
Audio Bliss I am very familiar with the recording and it is superb, highly recommended.
Just got the BDP-105 :)
post #359 of 672
3/15/13 at 4:50am
- mt14942
- offline
- 1,058 Posts. Joined 5/2007
Did you use the m/c analog outputs or the HDMI connection to the SSP-800? I used the HDMI out to the SSP-800 and was very impressed with the audio, but I don't have the 105 yet and with my player I prefer the HDMI route for bluray.
post #360 of 672
3/15/13 at 8:07am
- Sharp1080
- offline
I used the HDMI. I also tried the XLR outputs just for s__t and giggles. I think with this combo the HDMI sounds fantastic, I discovered the true capabilities of my SSP-800 when I connected the BDP-105 into my system. I was hearing spatial cues and details I had not heard before. I absolutely love this combination.
- Oppo BDP-105 "Sound Quality" Check Thread for Audiophiles
Currently, there are 1762 Active Users
(423 Members and 1339 Guests)
Recent Discussions
- › SEOS 12/AE TD12M Project 6 seconds ago
- › Bass that can be felt? 10 seconds ago
- › Star Trek: Into Darkness in Dolby Atmos 1 minute ago
- › Official Sony VPL-HW50ES Owners Thread 1 minute ago
- › New Onkyo TX-NR5008 & TX-NR3008 1 minute ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 1 minute ago
- › MITSUBISHI HC5, new 3D SXRD projector based on HC9000 2500 euros 1 minute ago
- › Power Sound Audio Discussion Thread! 2 minutes ago
- › Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23... 3 minutes ago
- › Microsoft fires the first shot in the "NEXT" generation.... 3 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
For those analog HDMI outputs???
