Originally Posted by brent_b_23
Thanks for all the help so far. Just ordered 2 dayton 18's and supplies for 2 boxes. I am still not sure if I will do 2 separate boxes or 1 dual opposed setup. Looking into amps now. Looks like the go to amps are the CV5000, inuke 6000, and Crown XLS5000. Any others I should consider? I want some expandability in case I decide to do 2 more woofers.
I would also put the EP4000 on your short list. I think this gives the most flexibility for pricing. Dual setup run one EP4000, with each driver getting 900 watts (assuming you go with SI's for a 4 ohm total load). Dollar output 275.00. If you decide to upgrade later you can pickup another EP4000 for another 275.00. Less upfront and overall cost than the CV while accomplishing the same thing.
Agreed. That's why most of us just start with at least 4.
As I mentioned to someone earlier; I paid less for 6 SI's, 2 EP4000's, and all materials than I did for my PB12/2 Ultra a few years ago.
just be careful it's not as fault-tolerant as more expensive amps i.e. you can break it. That's the other thing I know from 'personal experience'. Not the amps fault.
