I have a Panasonic Plasma (only audio out is SPDIF) connected to a fiio D3 DAC via the SPDIF. Attached to the RCA out on the fiio are two M-Audio BX5a monitors. I want to know the cheapest way to control the sound without having to adjust it from the back of the monitor, via a knob or remote or something.
The BX5a has two XLR ports on the back that I'm not using, if that helps.
Visual of how it is set up:
These speakers are connected via the TRS input to the left/right RCA out on this (fiio D3):
I use the optical in on this to connect to the optical out on my plasma. This all works so far, but I can't adjust the volume easily.
So if I purchased this (http://www.ebay.com/itm/BRAND-NEW-Axxess-Universal-Car-Amplifier-Bass-RCA-Level-Volume-Control-Knob-AALC-/271014397041?pt=US_Audio_Video_Remotes&hash=item3f19b78471) and two XLR to RCA cables, I'd be able to adjust the volume? I noticed the knob has 4 RCA cables (I'm guessing in and out)...would I need to plug the knob into the fiio as well as the speakers? I don't know how/ if I could do that.
Does anyone know if this will negatively affect the audio in any major way? Also, would I still be able to connect a sub with this setup, or is this the end of the line? Thank you!
