Speaker3.pdf 28k .pdf file
Please see attached, the front panel only will be gloss black already working on that part, I also built an outer shell shown in grey of attached photo. The shell was made more for looks it will allow me to wrap it in a material and tuck it under and then slide the box inside of it they are not attached at this point.
I find it hard to imagine what different materials would look like so I figured I would see what others think.
I already have Black Ash Vinyl Laminate that I purchased a while back and never used.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=261-610
but I recently came across 3M Carbon Fiber Vinyl which has great reviews,
http://www.carbonfiberfilm.com/?gclid=CMbEl8-g6LQCFQWe4Aod00kAww
The corners will be rounded plus the material will be folded over the front of the shell and tucked under, so the material must be flexable, I plan to use one piece with a seem on the bottom so it should look very clean.
what do you guys think
thanks
thanks
