All-
I know this has probably been rehashed a thousand times, but I am looking for help as far as using iRule to control my home theater / home automation. I have planned to have the following devices in my Home Theater:
- Optoma HD33 Projector
- Denon AVR2809CI
- Popcorn Hour A-400 Media Streamer
- Insteon Dual-Band Dimmers (controlled by an ISY994IR device)
I am trying to find the easiest solution to integrate the IR/Control UI in the room. Neither the Denon nor the Optoma has network capability, so is it easiest to buy two iTach IP2SLs and connect each one separately? If so, does anyone have any suggestions as to where to install the IP2SL that controls the projector? I already have the electrician adding an outlet over the room (in the attic) so I have somewhere to plug it in. Do you just install it in the attic and leave it? Are there better ways to do this rather than using the iTachs?
Another question:
I have an installer prewiring the house for network and video, and he has quoted me for several Proficient Mini IR kits, one for each room with a TV. If I am planning on using Baluns with IR support, or leaving cable boxes in the same room as the TVs, is there any need for these kits? I can buy the Baluns for cheaper than the kits, and they seem kind of old-school anyway. Any thoughts? I am not even sure I need them at all...
- Denon AVR2809CI
Another question:
