Originally Posted by
likemovies
But there appears to be one that is just the PS-10. I don't know where it fits in.
Lots of the models you are looking at are going to be somewhat on the same level of performance. If you can specify how loud (dB) you want to be able to achieve, it would be a lot easier to offer advice.
Most of the mass produced offerings give a lot of looks with a little less performance. All the glitz adds to the $$. Some of the best performing systems are ones that the general public could never just buy from BB or the Box stores. You might want to look into the internet direct systems that have been mentioned as they are well built and have excellent drivers compared to what's inside most of the lower priced BB offerings. Remember, everybody has to make a share when you buy from the local store. It is shipped many times before it gets to you and each handler adds his share. Look into the HSU, SVS, Klipsch that has been mentioned. But, my advice to you is to hold off on any purchases because the 300 or so spent could result in you being disappointed and then having to spent more and more to get the results you were after. Buy it once and be done.
Also, visit this site and see how these systems truly stack up to each other.
http://www.data-bass.com/systems
Pay special attention as to the extension of each system as truly measured.
http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M
I have heard these and for the money, they are solid. I was impressed.
Easy to tell that there is lots of differences between systems.
Good luck,
Keep cranking,
Robert
Edited by robertcharles - 1/15/13 at 12:41am
