Hey guys,
I currently have a Panasonic AE4000 and I have been very happy with the unit. I have had it about 2 years. The only issue I have is constantly cleaning out dust particles that create dark spots on the screen. It would not be so bad except I have to take the lower bracket off every time which is a royal pain. At this point I am ready to move on and buy another unit.
I am sure this has been discussed, is there any unit that is 3.5k and under that has a "sealed" lens area? I would even buy the new Panny if it was sealed off from dust. Are all units experiencing this problem?
My room is totally dark, Carada 126, 16 ft throw. I usually change the bulbs at 1200 hours running in normal mode. I do need lens shift as the projector is hanging down from the center of the ceiling about 5 inches.
Edited by denverb - 1/14/13 at 5:27pm
