AVS › AVS Forum › Video Components › Home Theater Computers › Ethernet cable splitter
Ethernet cable splitter - Page 3
post #61 of 84
Originally Posted by SAM64 View Post
This is AVS where the most in depth technical discussions are about...wire.
Here is a much more ridiculous thread about wires for you...
http://www.avsforum.com/t/1408260/stupid-question-regarding-speaker-wire
post #62 of 84
Wow that is hilarious. I will have to read the whole thing sometime. Me personally, I don't use anything but the highest quality coat hangers for my speakers.
post #63 of 84
Speaker wire and analog cables are the only ones I've been able to test personally and see or hear a difference.
I can't see any difference with HDMI or any digital cables.
I tend to buy the thicker AWG for long runs just to be sure but I honestly can't tell much difference in digital video or audio cables.
post #64 of 84
You definitely need heavier gage for long HDMI runs and over 25 feet you need powered cabling.
post #65 of 84
I agree with all of you guys, it's been absolutely ridiculous discussion.
I am out of here.
post #66 of 84
Usually good places like mono price only offer the longer runs in the thicker AWG
post #67 of 84
As long as you get a cable designed for longer runs there shouldn't be any issue. I have 25, 35 and 50 foot HDMI cables and I only have had issues with my 3 and 6 foot cables.
post #68 of 84
Okay. We've drifted to HDMI cables but at 50 you need powered HDMI or Redmere which is powered I believe.
Eithernet can go a much, much longer distance.
post #69 of 84
Thanks....notice how I posted in that thread, almost a year ago?
post #70 of 84
Originally Posted by Jim McC View Post
The Trendnet 5 port switch(TEG-S50g) is listed as "Unmanaged". What does that mean?
It's like a toaster that only makes toast. If you just need to let multiple ethernet devices share one wire back to your router, it's perfect.
It does mean one more wall wart at the devices' end. If that's untenable, you'll need to fish a second wire or (use a POE-capable switch and use a POE injector at the other end of the wire)
post #71 of 84
I had to stop at the first page...
I didn't get directional wire from monoprice. Now I'm screwed
Let me add that some HDMI devices are directional. Speaker wire, not so much.
post #72 of 84
I didn't get directional wire from monoprice. Now I'm screwed.
I skimmed into about pg3, it's pretty comical. People start throwing BMW and iPhone comparisons. Relating human perception and highly popular products to a need to buy something based on the perceived notion that the higher priced "quality" item manufacturers have stumbled onto some newer un-explainable phenomenon that improves the user experience.
They grasp for as many straws as possible trying to prove perception over science while ignoring the topic of wire biggrin.gif
post #73 of 84
Thanks. I have no idea what you mean by your last 2 sentences though.
post #74 of 84
You can use a switch powered by a little transformer (wall wort) or you can use one of the newer switches that are powered by the ethenet cable itself with a power supply at the other end coming from the router (Power Over Ethenet).
Just go with the first option.
Edited by Sammy2 - 1/17/13 at 1:59pm
post #75 of 84
If you don't have enough space for another wall wort just daisy chain an additional powerstip smile.gif
post #76 of 84
Edit: I've had to clean up the mess after someone daisy chained power cords. Pretty sure I lost a couple years off my life that day.
post #77 of 84
Well, the ethernet cable I'm going to plug into the Trendnet 5 port switch(TEG-S50g) is coming from my router. That will work, correct? I don't need anything else?
post #78 of 84
What do you mean? A power strip full of wall warts pulls far less power than one outlet on the first power strip can deliver. I have a couple situations like this because I have so many devices that have wall warts. What I need is a power buss with various voltages available from one transformer with different tap points.
post #79 of 84
That trendnet switch will need to have power as it isn't POE.
post #80 of 84
Jim, you've done an incredible job weeding through all the irrelevant info in this thread which should have only been 2 posts long:
1) Do I need a splitter?
2) No, you need a switch.
Buy your Trendnet switch. It will come with a power supply to plug into the wall. You'll also need a short ethernet cable for each of the devices you intend to plug into the switch. If you don't have these already, I recommend buying those at monoprice.com. Amazon may have cheap ones as well.
post #81 of 84
I will say that fire marshalls consider daisy chained power strips a fire hazard and I have seen this fire hazard happen. I highly suggest plugging power strips directly into the wall plug. If you need more power plugs then buy a power strip with more outlets.
post #82 of 84
Thanks Dave. I swear everyone here but you was just trying to confuse me.
post #83 of 84
Point taken. If everything is pulling a lot of watts it is a problem but a power strip full of wall warts isn't creating that problem.
post #84 of 84
We do tend to drift off-topic around here. While I have not used the monoprice switches because I got the trendnet on shell shocker from newegg for less, I do trust monoprice to put out quality product. Like Dave says, get the switch..
