Hi, hope somebody could help out.
Here's my setup
- Panasonic HDTV
- Samsung HT-C6900W home theater system
- Onkyo HT-RC460 AVR
- cablebox
- xbox360
I plugged all the deviced into HDMI inputs in the receiver, with HDMI going out of the receiver into the TV. The speakers are all connected to the Samsung, which goes into the receiver as "BD/DVD". The speaker wires have special plugs on them that only fit Samsung inputs. I know i can strip them off and wire them directly into the Onkyo AVR, but I'd like to avoid that as possible. The problem is that I get no audio. To get audio, I have to run everything through the Samsung, which only has 2 HDMI inputs. Any idea how i can get audio while using the AVR as my hub AND keeping my speakers hooked to the BD (one of the AVR inputs). Is it possible?
Any help is MUCH appreciated. Thanks!
Vlad
Here's my setup
- Panasonic HDTV
- cablebox
- xbox360
Vlad
But, given your goal, you only need to use one of the AVR's HDMI outputs anyway.
