Hello,
I want to build a Home theater pc, I'm a bit on a budget and this is what I plan to build:
CPU: Intel celeron G550 2.6GHZ
Motherboard: ASRock B75M R2.0 or ASRock B75 Pro3-M
(suggestions?, main difference the pro has this: http://www.asrock.com/feature/Blu-ray/index.asp and has also 4 ram slots which I won't be using and an 8pin motherboard connection insted of a 4 pin)
Ram: Crucial Ballistix ddr3 4gb 1600mhz 1.5V (non ECC) CL9
GPU: I will be using the onboard HD 2000
Cooler: Stock cooler from the celeron
Case: Epsilon HTPC1 (it's basically the same as the MS-Tech MC-1200 and Techsolo TC-2200 but without the PSU)
PSU: Seasonic SS-300SFD (The case only take SFX psu's)
Casefan:I'm hoping to use an Nexus 120mm PWM real silent fan. But if I take the "pro" motherboard (with 4 ram slots and 24bit audio) it will obstruct the 120mm mounting hole. So I can only use an 80mm fan... (Sharkoon silent eagle 80mm 1000 rpm in that case
BOOT-DISK: Crucial M4 64 gb or Samsung 840 120GB (not decided yet) (of course 120gb is better, but i'm on a budget
total: +- 300 euros
Storage: My raspberry pi will host all my music and video on a samba server
So I still have some questions:
1) My main concern is noise, I've chosen my components very carefully, I don't want to sit next to a tornado. Is this going to be a quiet system? Am i'm missing something?
2) I will be using openelec (xbmc on linux), Does anybody know if the celeron G550 support HD audio bitstreaming over HDMI in openelec? (dts HD master and dolby true HD)
3) I will be using my HTPC in combination with my Onkyo tx-nr807, I'm going to passtrough audio over HDMI to the onkyo, will the downscalling to 16 bit happen with the B75M R2.0, or is this only when u use the integrated audio chip?
4) Is there a problem with 24p content with the HD2000? :s
5) I also want to dual boot the openelec with windows 7, to play a game sometimes, nothing really heavy, trackmania forver nation, halo combat evolved, HAWX, all pretty old games, will they run on my HTPC?
6) So, I want to dualboot, can I do that with grub? I think mce remote wont work in grub
. Can I write a script in openelec that I can launch from openelec that says: reboot this computer and choose Windows 7 in grub. (He needs to do this only once,the next time I boot, I want to boot in openelec.) So default boot in grub is openelec and I can launch a script from openelec to boot the next time windows 7 (ONLY the next time
). Is this possible? Can anyone help me with that, are there guides on the internet?
7) Will this HTPC play all content I throw at it? (I don't care about 3D
8) Is it powerfull enough to transcode a movie (PLEX) and playback another movie at the same time? So the kids can watch a movie on the tablet (transcoded) and the mother can watch a movie on the television (regular playback)?
These are all my questions
. I hope somebody can help me figure them out;)
Thanks in advance
)BOOT-DISK: Crucial M4 64 gb or Samsung 840 120GB (not decided yet) (of course 120gb is better, but i'm on a budget
)total: +- 300 euros
). Is this possible? Can anyone help me with that, are there guides on the internet?7) Will this HTPC play all content I throw at it? (I don't care about 3D
)8) Is it powerfull enough to transcode a movie (PLEX) and playback another movie at the same time? So the kids can watch a movie on the tablet (transcoded) and the mother can watch a movie on the television (regular playback)?
. I hope somebody can help me figure them out;)Thanks in advance
. Just realised this
