Hey all,
spent a little time building some custom patterns.
Attached you will find 6.5% (THX size I believe) and 4% window sizes, with 0-100 grayscale in 10% steps, full saturation patterns for primary and secondary colours and 75 lum CMS patterns also for your primary and secondary colours.
Unfortunately since I am not in posession of a decent BD authoring tool, I have only managed to create these as single standalone disks which need to be burned and played separately, ie grayscale needs to be burned separately from CMS and so on. This means you will end up with 3 disks in total for each window type.
Note the disks play immediately, there is no menu system, there are however 30 second gaps between chapters so you will be using the pause button alot no doubt and they have all been recorded at 24fps. Oh and before I forget, i didnt mark any of the patterns with markers to identify them, hence the need for a small chapter guide. Next time i'll try to figure.
To use these patterns they need to be extracted and burned to disk using ImgBurn. .The files have been compressed using 7zip, which you'll need to install to extract the BDVM and CERTIFICATE file.
Once ImgBurn is open select mode, then build, then goto the options tab, ensure file system is UDF and the UDF revision is 2.5.
Drag the extracted BDMV and CERTIFICATE files into the large empty window on the left (second window below where it says 'source'.)
Put an empty DVD in and record!
Maybe If I can afford it, I may invest in Encore, but until then this is as good as it gets!
Appreciate your feedback.
Enjoy!!
6.5% THeX Size Windows.zip 652k .zip file
4% Windows.zip 706k .zip file
Windows chapter guide disk 1,2 and 3.zip 7k .zip file
Ps - if there any are custom pattern requests let me know, i have it down to a fine art!!! (i think!!)
Im thinking 12% and 15%
Just wanted to thank Alluringreality, dr1394 and visca for their assistance!
Edited by ndaa75 - 1/15/13 at 10:21am
Enjoy!!
