I currently have this older Onkyo HTIB speaker set up: http://www.us.onkyo.com/model.cfm?m=SKS-HT500&class=Speaker&p=i
I have the Pioneer 1121 which allows me to set the sub crossover at 50, 80, or 100. The front speakers are rated down to 55 and the center is rated down to 65.
Would it be recommended to set the sub crossover at 80 so there isn't a gap in the frequencies? Do the speakers really go as low as they are rated?
Also, if I set the crossover higher at 100 will that improve mid range and high frequency sounds?
