Is this not yours from
http://www.avsforum.com/t/1240499/faq-for-the-3d-htpc/900
FAQ for the 3D HTPC :
The information is wrong. First BR 3D "support" is ambiguous. It's the software player (typically TMT or PowerDVD) that reads BR 3D, decodes MVC (Multiview Video Coding, the BR 3D video codec) and converts to a 3D video format (there are many 3D formats, depending on your 3D display). The roles of the graphics card are:
- Accelerate MVC decoding. If CPU is powerful enough (e.g. triple core or more), this may not be necessary.
- Send 3D video format to the display. Some formats are within HDMI 1.3 specs (e.g. Side by Side (Half), Top and Bottom, checkerboard, interleaved). In this case almost any graphics card is fine. Frame packing is HDMI 1.4a and requires the latest graphics card.
HD 5450-5670 HD 5750- HD 6310 (E-350) HD 6xxx (E-450, A Series, dGPU), HD 7xxx GT 210-240 GTS/X 250- GT(X) 430-460/520-560/all 6xx GTX 465/570- Intel HD Graphics (Celeron/Pentium SNB) Intel HD Graphics 2k/2.5k/3k/4k (Core i3/i5/i7 SNB/IVB)
MVC hardware decode No Yes No Yes Yes No Yes Yes Yes Yes
HDMI 1.4a 3D (Frame packing) Yes Yes - Yes Yes Yes Yes Yes No Yes
Frame packing to 3D display + HD audio to HDMI 1.3 AVR No No - No Yes (LPCM only) No Yes Yes (LPCM only) - Yes
Frame packing + HD audio to HDMI 1.4a AVR / 3D display Yes Yes - Yes Yes (LPCM only) No Yes Yes (LPCM only) - Yes
Remarks on the two cable solution of HD audio to HDMI 1.3 AVR and 3D video to the display
1. This works if and only if HD audio controller of the GPU supports dual audio stream, and only NVIDA and Intel GPUs support it. One audio stream is assigned to AVR, the "secondary" display, the other to the 3D display, "primary" display, in extended desktop mode. Select AVR as the sound playback device in the player. BTW HDMI and DVI with a DVI-HDMI adapter are completely equivalent in NVIDIA and Intel (audio over DVI port is disabled in some LGA 1155 mb, however).
2. AMD HD 5xxx/6xxx/7xxx GPU behaves differently. Usually you will see an HDMI connector and a DVI connector and/or a DisplayPort connector in the GPU and any of:
- HDMI connector
- DP connector with a passive DP-HDMI adapter
- DVI connector with AMD's proprietary DVI-HDMI adapter
works as a HDMI 1.4a connector that supports Frame Packing 3D video, HD audio and YCbCr color space as well as RGB. However if two displays are connected to the GPU at the same time, then only one connector works as HDMI and the other connector always works as DVI (no Frame Packing 3D video, no audio, only RGB color space). Precisely speaking, if you use HDMI and DP/DVI, then HDMI always works as HDMI and DP/DVI works as DVI; If you use DP and DVI, then DP always works as HDMI and DVI as DVI. In other words, HDMI-likeness decreases in this order:
HDMI > DP > DVI
That means, unlike NVIDIA and Intel, you can't send Frame Pakcing 3D video over one of the connector and HD audio over another (you can still send other 3D formats such as checkerboard, SBS, TAB, interleaved, however). Apparently this is because of a limitation of the HD audio controller of AMD GPU, i.e. non-support for dual audio stream.
A workaround is use another GPU to send HD audio:
a) If it is a discrete AMD GPU and your CPU is Intel Clarkdale/SNB/IVY or AMD APU, then activate its GPU and use it to send audio.
b) If it is a discrete AMD GPU and your CPU does not have integrated GPU, then add another cheap GPU such as HD 5450 (~$20) for audio. The second graphics card works even with a PCI Express x1 slot! (Just cut the closed end to make it an open end.)
c) If it is iGPU of AMD APU, then add a cheap discrete GPU such as HD 5450 (~$20) for audio.
The chart did not copy and paste...
So what can I do??
Rich
