AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Irule Images & Backgrounds?
post #1 of 2
Hello all! I am thinking about buying the $99 Irule app.
Question: Is there a good place I can download some images and background to get started?
I saw some awsome ones in this forum but they were just screenshots frown.gif
Gear mentioned in this thread:
post #2 of 2
The irule builder has a lot of backgrounds and buttons all set to go. Channel icons, play, pause, stop, in 3 different sizes and colors.
Once you know the size of your device, for example my Kindle Fire uses 1024x600 backgrounds, you can create your own in the correct size, or download some from the internet that are the right size:
All the buttons in those images are available already in the builder and the backgrounds I found myself on the net and uploaded.
Hope that helps. Post in the main thread with any issues you have as you begin down the irule path.
  Back to Forum: Remote Control Area
