Status update, I went to the sherwin williams store and they had the BAC wiping stain but they can't carry the BAC dye concentrate (because california).
I was looking at using a transtint dye for the dye component.
Would it be ok to go with the BAC stain and use the transtint with it instead of the BAC dye concentrate?
