Make sure it will work with 6 ohm speakers. Should. But ask if it works with the Pioneers that they carry.
It's definitely not that the Lepai is incompatible with the Pioneers. Many people have reported using them successfully together. If it is a broken speaker, unlikely it would be both (possible, but much less likely). Have you tried running one speaker with the Lepai? Then the other?
