AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Need suggestions on replacement for LG 55LM9600
post #1 of 4
To make a long story short I bought and returned 2 55lm8600s due to light bleeding, bought a 55lm9600 which was great for the 1st week until it died.
The LG quality is so bad that the LM9600 is going back and I need to find a great replacement at a good price if I am to "save face" with my wife.
Looking for:
Lcd/led
55 inch
Passive 3d
Wifi with a decent browser
Thin bezel (needs to fit in 49.5 inch wide space)
$1500 - $2000
In closing I would stay very far away from LG - I tried 3 times to like them.
Thanks for you inputs
post #2 of 4
The only other passive 3d lcds that I'm aware of (someone feel free to correct me if I'm wrong) are Panasonic and Vizios. I prefer passive myself, but you are limiting your choices if you don't like LG. Check out the Panasonic and Vizio threads to see if anything interests you.
post #3 of 4
I will check into those.
Chris
post #4 of 4
Toshiba makes a line using the passive 3D technology as well.
