Originally Posted by
AdamsAutoAdvice
So just download the CapDVHS with the proper drivers and plug it in with a Firewire cable to a computer and it should work?
Depending on what firmware version the 3400 is running, yes, using CapDVHS with the proper drivers should allow you to capture stuff via FireWire.
The easiest way to get the proper drivers and CapDVHS installed is to use my Windows Installer .MSI package, which can be downloaded from
http://www.sendspace.com/file/26fzqx
(This download site has deceptive download links that try to trick you into download junk you have no interest in. Use the download link toward the bottom center of the page that has a light blue background and says "Click here to start download from sendspace")
This must be installed on a 32-bit version of Windows! It supports Windows XP, Windows 7, and Windows 8. There is no way to capture FireWire using 64-bit Windows.
-TNO821
Edited by TNO821 - 2/2/13 at 10:56am
