Hello,
I have a house that is pre-wired for surround sound for 4 ceiling speakers. The "listening space" of the living room where I'm putting in surround sound is 11 1/2 wide by 15 1/2 deep. So I'm basically 15 1/2 ft away from the tv which is recessed into the wall. The system will mainly be used for watching tv/movies/video games. Maybe 10% of the time will be just music.
I have my eyes set on MartinLogan Helos 100's for the 4 ceiling speakers and a Motion 8 center with the Dynamo700 for sub all powered by either a Pioneer SC-61 or Denon 3312CI. My goal is to spend under 3000 for all the items buying online and will install myself.
Question #1 Am I going overboard with Helos 100's for this room size or would Helos 10's be fine or should I be looking at a different speaker all together for my setup?
Question #2 Is the Motion 8 a good center to pair with the Helos 100's?
Question #3 Is the Dynamo700 a good match with Helo's 100's and the Motion 8 or do I need the Dynamo1000?
Question #4 Which receiver is better for these speakers, the Pioneer SC-61 or Denon 3312CI or do you recommend something else? Also I do play call of duty so I can't have any signal lag issues.
Question #4 After installing everything, is it really difficult to calibrate? I know how to use a receiver on a basic level but I've never tried to calibrate or program one. I'm just wondering if it's absolutely necessary to be an expert or hire one in order to get it to sound good.
That's it for now. I appreciate any/all advice.
Thanks for your time.
