AVS › AVS Forum › Audio › Soundbars › need help; is the samsung 2.1 450 soundbar with 300 watts the same audio as a simulated 5.1 yamaha soundbar from 4 years ago
If the Samsung and the Yamaha have the same drivers, crossovers, power output, cabinet dimensions and simulated 5.1 processing, probably yes; otherwise, probably not.
So, probably not...unless you can think of a reason why two different products with no similarities other than wattage, and produced several years apart by two different companies, might sound alike.
