Originally Posted by
SoundChex
You might try
stacking three of
these (link) to get 1 IN, 4 OUT . . . I doubt signal degradation would be significant, but you would need to TEST...
_
These are made by Shin Kin in Taiwan . Here are the specs you can convert grams to ounces by google. It is about the size of a VCR tape. What I don't understand is the power supply being "optional" unless that means for different countries than USA.
Since both output ports are always ON. I figured all I need to do when using my new Sony MDR DS6500 wireless headphones is to silence the sound bar by simply hitting the mute switch on the remote or turning the soundbar off by switching inputs to analog where nothing is connected. Since my Panasonic TV, Direct TV and Blueray/or game are all connected to the router through a Ethernet switch, all have toslink connections. I asked Shin Kin about the warranty and their reply was to contact the seller? I see the item also on fleabay but as a Florida resident Shipping and state sales tax is added so Amazon appears to be best place
www.shinkin.com.tw/url/selector/
AOS-42TR-B
4x2 Active Digital Audio TOSlink Optical Selector Switch
Connect up to four optical sources to a set of two simultaneous outputs
prevent wear and tear on TOSlink cables and I/O jacks when manually disconnect and reconnect cables
Can be mounted horizontally or vertically
4 Optical Digital Inputs via TOSlink
2 Optical Digital Outputs via TOSlink (simultaneous outputs)
Color : Black Housing with Light Gray Screen Printing
Dimension : approx. 184 mm x 155 mm x 50 mm (Main Unit Only) 7.24X6.1X1.97 inches
Weight : approx. 690 grams (Main Unit Only)
Power supply : DC 9V / 250mA (Optional)
Remote Power Supply : CR2025 3V lithium button cell battery
Remote Custom Code : 866B
Edited by generallee - 3/23/13 at 6:20pm
