Looking for ideas/info on floor rising projection screens.
It is not possible to fix the screen to the wall and the for WAF, it isn't possible to just put a ceiling mounted one i. However, I just came across the floor rising screens and think that would work, especially since I can easily build it into the floor (crawl space underneath and joists run in a way to make install easy). The screen would be installed in the floor in front of a plasma hung over the fireplace. Behind the screen would also be a L/R channel. Below is a picture of the setup to give you an idea where it would go.
I am having a hard time finding a floor rising 120" AT screen that is motorized as well. Any ideas/links as to how to DIY this or who sells it economically (i.e., under $1k)?
