Hello All,
I am happy to say that I am new to this board but have checked out many posts in the previous years to help me get through my issues. I will explain my system and new home hoping someone can help me.
I have a single closet has the following items inside:
Direct TV HD-DVR receiver Mod # HR24-200 with RC65RX remote (Included)
2 - Direct TV HD receivers Mod # H24-700 with RC65X remotes (Included)
I have one hdmi cable running from living room tv to the HD-DVR box as well as an HDMI running from each HD receiver to the tv on the patio and the other in my bedroom.
I have a MRF-350 Universal base station with an emitter running to each ir signal eye on the receivers. My problem is that i have a universal remote MX-450 that is programmed to work my direct tv receivers. The bad thing is that all of the direct tv receivers are on the same program code so they all change when I try to change one channel.
I think all that I need to be able to do is program the boxes to somehow be on a different remote signal and then be able to program the universal remote to that remote and then it all work individually. Direct TV customer service says it can't be done or at least they don't want to help because I am using a different remote than theirs.
Please help! THANKS! and let me know if anything is too hard to follow or you need more information.
