I have the 43" E450 Samsung ( 720p) and 50" TC-P50U50 (1080p) set up side by side hooked up to Dish HD
I am seeing a quality difference despite the claims by many that at normal viewing distance on should not be able to see the difference between 720p and 1080p
Note I have a smaller room and can only be max about 8 feet back from any screen, I wanted smaller but LCD/LED look terrible on Dish HD even after 2 techs checking the set ups and trying many brands and quality in that tech. The issues I have are less noticed with plasma.
The one issue is that the I can not find a 42" 1080p plasma to compare to. Best buy had an open box 50" so I pushed it back about 1.5' to help compensate for the size issue.
THe P50u50 is set about 1.5 feet back, and still looks sharper believe me, I wanted it not to be true in some ways since I kept reading the eye cant see the difference. . Yes it is close at 7+ feet,but there is a difference noticed. E450 just looks softer in faces. Watching faces on the 1080p panel set at 8 feet, I could see detail that was softened on the 720 panel. Side by side I would go with the 50" but I still have an issue with the size of the panel for the room. Plus I was not able to get the flesh tones right P50u50 and whites still are a bit gray compared to the 43" E450. I have found various settings on the net and tried WOW, but still not qite getting it to be ideal to my eye. However that said, still there is a sharpness on the 1080p not present in the other. The P50u50 has some hot spots even thoug the blacks are better some areas in the whites are getting blown out even though the whites are on the gray side. Also shes tones are on the greener side it appears. But as I said, even so, there is a sharpness not in the E450 at the current settings.
I am debating how much how this is due to resolution or how much of this is the quality in the panel.
that is creating what apears to be sharper detail. But I still think I am seeing a more defined detail even thoug the TV is pushed back further.
So much of the softness is due to the panel quality vs the resolution of the panel?
