Originally Posted by
coctostan
Yeah, they have some cool speakers, but they are a little outrageous on the price IMO. They are basically for high-end installs only...aka $500k builds and up.
The funny thing is that all of their speakers use off the shelf parts. Mostly B&C, BMS, 18Sound and JBL. Much of the same stuff you will see the guys on here use. I'm actually using the same horn they use in their 2nd from top of the line speaker. It is an older JBL horn. Their DSP and amps aren't even very special. Pretty much run of the mill 48db slopes and nice class D amps. The DSP offers an interface for slight tweaking which is good for installers.
+1
I agree,.. it a brute force pro audio approach, in the world of high end HT design/installs,
and the margins therein. Also, private screening rooms for the stars, etc, according to the individuals at the company. Most drivers do appear off the shelf, but they do use a carbon fiber 7", in a somewhat of a compression driver, in it's loading, in their biggest screen channel offering.
In their words;
"41-pound ultra high-output (114dB / 1 watt) compression driver. Its 7-inch carbon fiber diaphragm provides pistonic motion over three and one half octaves, resulting in the most effortless, coherent, and dynamically correct rendering of vocals and instrumentation possible. Dispersion and acoustic power transfer are controlled via a 28.5”-square constant directivity horn with over 800 square inches of effective radiating surface – more than 40 times the radiating area of a typical cone midrange."
7" compression drver
sweet.
If you've ever seen it in person, up close, you know what I mean by compression loading.
No need for further discussion of these, I just wanted to point out what was out there in high capability in-wall/in-ceiling offerings.
