Originally Posted by bomberjim
Absolutely not true concerning 3 (or 4) tb drives and WHS 2011, you're misunderstanding the limitation. You can certainly format to the full capacity (i.e. no splitting) and use 3tb drives on WHS 2011 unless your motherboard doesn't support it. Slowness is also not an issue, unless your trying to use it as a desktop as well.
I can understand your need to setup the device "behind something" because of a lack of hard-wiring, but what makes you think a NAS is necessarily quieter? The CPU/drives need to be cooled and noise is a factor of the fans. The hardware's the same whether it's called a NAS or a server. Often NAS's are quite loud because of the small form factor. If they're not loud, then they've sacrificed some cooling. Hardware is hardware, there is no free lunch.
You can certainly use a NAS in your situation, but a server would also work fine and probably provide a better/cheaper solution in the long run. If you need a small form factor, there are cases/motherboards that fit the bill. You can even use a full blown raid 5 card with WHS 2011, but raid 5 is generally overkill for home environments. I really think you're looking at this the wrong way. What do you think a NAS does that a server doesn't?
Thanks for clearing this up.
I meant to comment on this too and forgot.
YES YOU CAN USE 3TB DRIVES WITH WHS.
I HAVE 8 INSTALLED IN MY SERVER. All formatted as standard single partition and sector size. Nothing special you need to do.
WHS certainly can take 3TB drives and even 4TB drives without issue. It's only old hardware that can not. Any new motherboard can tolerate it without issue.
. I dont trust another brand. Even if they are cheaper and just as reliable. ASUS and Intel chips are always a must for me. even if the equivalent is "better".
