I'm looking to get the picture on my viera looking the best it can. I did some googling and found this site and it seems lots of people recommend using what appears to be a free blu ray disc aiming at calibrating the display ( avs hd 709). I, however, don't have a blu ray player or interest in buying one. What I do have is a panasonic viera th-46pz80u, an x box and an hdmi cable. Is there just a regular dvd version I can download? Or even better, since i'm a bit technically challenged, is there a good/cheap one that is readily available that you'd recommend since I don't really want to deal with burning dvd's. I assume you just plug in a dvd and it gives you steps to follow?
