Originally Posted by
neuspeed94
The proposed setup looks alot better than the current setup. Make sure the center channel is not placed behind the TV. It needs to sit right in front of the TV.
Thanks! That was ashley's subwoofer graphic. Center channel will be under TV.
No mention of the front and rear speakers, I'll take that to mean that I've got them in good locations? That would be thanks to this forum and other similar threads!
nograveconcern
There are no seats in either of those that don't require turning your head to view the TV. Can you put the TV on the wall to the right and the couches against the wall with the 3 windows? That or turn the sectional on an angle that matches the TV.
Good points.. we'll look into those rounded sectional sofas too, so then there will be a couple seats in prime viewing area.
Problem with current setup is that is is very closed, hard to get to a seat. If I have an opening between the 2 sofas that makes it better. Full sectional makes it closed again.. =/
Here is the best I could come up with for the tv moved to south wall. Looks like I can use wall mounts instead of ceiling mounts this way... hmm.
Edited by xanderak - 1/17/13 at 8:33pm
