AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › Any issues with using loctite?
post #1 of 4
I'm thinking about using a little bit of blue loctite on the bolts that go through my wall bracket to my lcd. i'm just a little nervous they'll back off with vibrations from volume and such. is there any issues with using some as long as i don't plan on using so much it seeps into the display or anything.
post #2 of 4
I'd use lock washers instead.
Edited by astrodanco - 1/27/13 at 11:49pm
post #3 of 4
Originally Posted by svt2nv View Post
...any issues with using some...
No.
post #4 of 4
...is there any issues with using some...
But there also isn't any reason to.
  Back to Forum: Tweaks and Do-It-Yourself
