Looking for some bookshelf sized speakers for front left and front right, dimensions no larger than about 18" H x 14" W. Black or white color.
Also need a matching center channel
- can be a little larger than L/R
- Must be able to wall-mount the center channel somehow, or maybe put it on a discrete stand
- Depth not really a factor as it will be mounted inside of a custom bookshelf above a tv
All three will be powered by the receiver, which is TBD. However it will be high end and probably be capable of at least 100w per channel.
