AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Upgrading Firmware RX-V473: USB works, Network didn't
post #1 of 2
Upgraded to 1.14 via USB, was surprised a little that when I tried using the Network and got "Device Error". Went to USB option, no problems
For owners info,
MitsMarty.
post #2 of 2
talking to myself da, well, Yamaha when you do the next firmware update you gotta learn to flush the Airplay ones and zereos out of the top of Device Q, WHEN the unit goes into standby (at least this at a minimum)! Your Scene settings should do that on power up too but it doesn't. I know you wanna kiss up to Apple but its real bad that once Airplay is played, its at the top of the device Q until you use the IR remote to override..
FLUSH DA Q.
da, talking to myself,
MitsMarty
