AVS › AVS Forum › Audio › DIY Speakers and Subs › Full DIY HT Replacement - SEOS Tempests + SEOS Fusion 10s + Dayton 18s
Full DIY HT Replacement - SEOS Tempests + SEOS Fusion 10s + Dayton 18s - Page 6
post #151 of 233
i used the 4 inch guys that came from acrytech
http://store.acrytech.com/4-Texture-Roller-2-Pack-Refill.html
you can get a 9 in one as well
http://store.acrytech.com/9-Texture-Roller.html
prob is you cant dnk the 9 in one in the bucket fo duratex it too big
also i did 2 pretty thick coats, IIRC carp you only did 1 that may play into it
post #152 of 233
post #153 of 233
not much to update, had to order some things from PE to finish up the Fusion 8s - hopefully ill get to them this weekend. just gotta do Xovers and paint
started the TV stand replacement. - check out this sweet sketchup i made - still need to figure out rear stands
post #154 of 233
What kind of extra things did you order? If it makes sense I could always add something to the kits, or make it an option.
post #155 of 233
i needed some more barrier terminals for the xovers and some binding posts as i didnt order any from you because im dumb
not sure if everyone uses barrier terminals, i like them, adding them to the kits might work as an option, guess it depends on the person, i use the larger ones as i dont like using the small spades
post #156 of 233
BOOM
post #157 of 233
I'm just a lurker on your thread but had to say, thats a damn nice TV stand smile.gif Good work.
post #158 of 233
Wow dude! How did you make that?!? Is that solid maple or something, or is it plywood. Looks awesome.
post #159 of 233
i designed it but had a contractor friend put it together for me. its birch ply (i think), with i assume pine face board. He’s bringing it over today unfinished. I’ll finish it with some sort of gel stain and some semi-gloss ploy
ill get some high quality pics tonight. thats the one he sent me yesterday
post #160 of 233
Hey Sibuna, I sent you a PM and was wondering if you got it?
post #161 of 233
yea i got it i just forget to reply to things somewhat often
post #162 of 233
That tv stand looks really nice. One day when I'm done building my speakers, that will be my next project. The stand looks curved but that could be the camera.
post #163 of 233
TV Stand in the house
ill most likely finish it with a dark gel stain maybe mahogany or rosewood. cover with a semi gloss poly
post #164 of 233
Went with Red Oak
only 1 pass so far
Back
post #165 of 233
That looks really nice. Well done.
post #166 of 233
Thanks, im happy with how it came out, cant wait to get it finished and hauled up stairs
For those curious about how it was made, its simply 3/4" birch ply that is nailed and glued , 1x2 pine face board on the front
supports are 2x8s, top and bot are nailed/glued in and the middle one is simply glued in there
pretty much built exactly like my sketch a few posts up
finial dimensions are 30H x 25D x 60L - which should be large enough to hold all my HT Junk
post #167 of 233
put a 2nd coat of stain on the outside of it today as well as the top face board as it was a little lite. looks much richer now. Will start the poly process tomorrow
also strated the grills for the subs and the xovers for the fusions 8s
the camera in my phone is such a POS
post #168 of 233
got less done yesterday because the power went out randomly (entire town) was out for hours
so i finished gluing the frames for the grills on the subs by candle light (oil lamp)
i may have gone insane
post #169 of 233
Hey Sibuna,
I didn't see if you mentioned it or not, but where/how are you planning on using the Fusion 8's?
Now that I finished my Tempests I am thinking about my surrounds and if I went wave guide I think these would fit on my columns.
Curious to hear your impressions and how they might integrate with the tempests.
post #170 of 233
I'm building the Fusion 8s for my Dad for a 2.1 system for him (havent decided on what to do for a sub yet) so i wont be integrating them into the system with the Tempests and Fusion 10s
post #171 of 233
That's cool for your dad! Well if you have an opportunity to throw them in the mix as surrounds for a quick listening impression before you give them to your dad I would appreciate it. If not I understand.
post #172 of 233
im planning to have them done in time to take them down to Rills GTG in April
post #173 of 233
post #174 of 233
first gloss coat down. itll prob take 3 with sanding in between each one
post #175 of 233
Great looking DIY wood TV stand you have made! Plenty open, no heat venting issues there.
I've seen the thd rod flexi stands, like what you did better.
About 1 month ago I made a DIY wood storage shelf for below my dartboard, that needed to be able to handle people sitting on it and also kids climbing on it to remove their darts.
6ft long, 15in deep by 24in high. Ready to play darts, and can catch those stray darts safely also with the cork.
post #176 of 233
3rd coat of poly on
post #177 of 233
Epic setup Sibuna. Watching this build closely because I may replace my paradigm monitor 7's with tempests :-). Keep up the good work.
post #178 of 233
Holy Crap!!! That is awesome.
post #179 of 233
this is what i have for the xover for the fusion 8s. tested and it works, just want to make sure its all good before i solder it together
post #180 of 233
I don't think that is a good layout for the inductors. I would try to lay down the one in the middle and rotate the inductor on the far right to 90 degrees of that inductor laying down.
