HTPC Software
post #1 of 5
I have a Lenovo Q180 lying around and was thinking about turning it into a HTPC. I would use a HDHomerun dual for TV interface (I am 1 mile LOS from Sutro Tower and get 60 digital channels OTA from my 4 bay Wingard). Which software would you recommend from among:
NextPVR – DVR for Windows
MediaPortal – DVR for Windows
Windows Media Center
Any others on your short list?
post #2 of 5
I too have an under-powered Atom box (Acer Revo) and found Win8 MCE works pretty good on it.
post #3 of 5
This would have better feedback in the HTPC forum rather than the Great Deals found forum
post #4 of 5
OK, I am confused. Under Home Theater Computers there are 3 fora:
Great Deals
Mac
Linux
Precisely which forum were you referring to as HTPC???
Thanks. Dave
post #5 of 5
Great Deals
Mac
Linux
Thanks. Dave
If you scroll further down, below those 3 forums, you will find you are actually in the main HTPC forum, and the posts are a bit below the forums you listed above.
http://www.avsforum.com/f/26/home-theater-computers scroll way down, you will find the posts :-)
