Featured Stories
how long is a typical "break-in period" for speakers?
AVS Top Picks
- coytee
- Trader Feedback: 0
- offline
- 917 Posts. Joined 3/2006
- Select All Posts By This User
Different people have different opinions.
I once asked one of the engineers at Klipsch when at their corporate open house. His comment was (paraphrased) 'I take two drivers, hook them out of phase. I run "X" volts through them (I forget the number) for about 20 minutes and consider them done"
Think about this...
Let's say a driver actually NEEDS 200 hours to break in. Now, pretend you're the person who's designing the speaker and has to see if this driver will work for your application.
You get the driver....you can't install & test as you need to know how it will work when broken in. Now, you have to hook it up and wait 200 hours for it to be broken in. Although that's more than 8 days, let's just call it a week.
So now, you have to breakin the driver for a week BEFORE you can test it to make sure it fits your needs. If it does, you're done. If it doesn't, well...oops, you have to get another driver, test it for 200?? hours.... wait another week?
How efficient is this situation?
Some people say they believe the breakin period is more for the ears than the drivers. Given some of the conversations I've had with people who design some of these things, that tends to make more sense to me however, I'm certainly no expert on the subject.
I've always had the feeling of plug them in, turn them up and enjoy them!
- Bill Fitzmaurice
- online
- 5,228 Posts. Joined 11/2009
- gtpsuper24
- offline
- 1,892 Posts. Joined 8/2008
I've always tested the speakers out first by listening to something i'm familar with and then take a few notes/mental of what it sounds like. I let them break in around 4-10hrs or so and come back and try out that exact song and the bass is especially improved.
- arnyk
- Arnold B. Krueger
- offline
- 7,431 Posts. Joined 10/2002
i am referring to the 'BIC FH6-LCR' in particular. i have been running my cd player while away to speed up this process (about 40 hours so far). it has made a big improvement, but dont think i am there yet. how many hours do i need before i can be reasonably sure this is about as good as its going to get?
Most what people call speaker break-in is actually listener break in.
Many of the changes that happen when speakers are first used happen in a few seconds, and don't change the sound of the speakers that much anyway.
Furthermore, if you let speakers rest for a few days, some the changes ascribed to break in back themselves out, and then go back in in a few minutes after you start using them again.
You probably have something far more important to worry about! ;-)
If you haven't noticed, car engine break in isn't the long drawn out nasty process it used to be. That's because car motors are made that much better to start with.
- gtpsuper24
- offline
Actually with cars at least with Honda manufacterering where I work they cars are put through some fairly long drive times before they leave the plant. Dyno tests ect.... Engines are driven hard right after assembly for quite awhile. So the "break in" would already have occured at the plant not while driving home from the dealer. Car engines have drastically improved every few years and even the last 10yrs some have gone through some significant changes.
Speaker drivers are still pretty basic and most haven't changed much in the last few decades.
- Bill Fitzmaurice
- online
http://www.gr-research.com/burnin.htm
http://www.gr-research.com/myths.htm
My experience mirrors that of the GR guys.
- arnyk
- Arnold B. Krueger
- offline
I'll raise you two AES Fellows who have specialized in speakers for the past 30+ years being Earl Geddes and David L Clark.
I've never heard of your guy(s), ever but I don't know if you have heard of mine! ;-)
- Bill Fitzmaurice
- online
- NewHTbuyer
- offline
- 413 Posts. Joined 7/2008
- TheCure
- offline
- 16 Posts. Joined 6/2011
now i am going to use the 'mic' and have my pioneer re-calibrate itself, then redo the EQ more to my tastes. maybe if i can adjust the EQ for the center (horn) different than the others (silk dome tweeters) i can make it sound less "raw", then i will have the best of both worlds. my pioneer is supposed to send the 'center signals' to the 'L'&'R' (if you dont have one)...... which i have been happy with doing. but when watching batman3, the dialog was all but missing. you could barely here the dialog and then BLASTED with effects. for an experiment i hooked up my old floor speaker and turned the "center on" in my receiver menu, adjusted the EQ and signal level, and voila! it sounded normal. AND THUS..... me getting a dedicated center speaker. think i would get the matching Polk center instead if i could do it over again. may still despite the loss on return shipping if i can not get used to the horn.
anybody else mixing tweeters?
- cel4145
- online
- 7,820 Posts. Joined 3/2009
I've always wondered, Bill, is the physics of it more of an exponential or order of magnitude thing? Seems like I believe I can hear the most break in after the first couple of hours with speakers, and then maybe again after 10 or 20.
Caveat: this is assuming it's not psychological. LOL
- Bill Fitzmaurice
- online
- cel4145
- online
It's the same physics that explains why a pair of leather shoes get more comfortable with use: the suspension parts soften. Most of the softening takes place fairly soon, though the process never stops entirely. And just like a pair of shoes the driver suspensions stiffen back up a bit after a period of non-use, but after the initial break in period it only takes them a few seconds to loosen up again.
Thanks, Bill. That makes sense.
Does it include the cone materials as well? Given all the different types of material used in cones now, I had wondered whether or not it goes through any transformation through use.
- Bill Fitzmaurice
- online
- Kensmith48
- offline
- 1,185 Posts. Joined 12/2001
The full-range mystery: The break-in process (with all of its negative attributes) simply happens to be most intrinsically connected to, and is most audibly discerned through a full-range transducer. This is because a full range simply has the ability to augment the very subtle higher frequency centered distortions, squeaks, and squawks that a crisp new speaker is capable of producing. Once again, if it is a full-range speaker and if it sounds bad out of the box, don’t wait for a miracle to happen; send it straight back to whomever you got it from because the speaker has serious problems. If it sounds quite good but has a very subtle graininess, or a few mild distortions, or the sound is crisp but still pleasant, then you’ve got a keeper! Sit back and be patient, and you will be pleasantly rewarded within 15-20 hours of moderate playback levels – this amount of break-in time will get you to about 80%-complete break-in. Beyond that, a functionally full and nearly complete break-in period of 200+ hours is quite reasonable and is to be expected.
- Bill Fitzmaurice
- online
This is what Eric Alexander at Tekton Design has to say:
There are those who deny that break in occurs at all, and say that any changes you hear are the consequence of you getting used to the speakers. That's not true, but neither is the other extreme.
- jima4a
- offline
- 801 Posts. Joined 6/2011
- arnyk
- Arnold B. Krueger
- offline
Yes, the measurements show small changes. However, shifting the Fs of a speaker driver a few Hz does not have that much of an audible effect.
Check these articles out, which shows the actual effect on the T/S parameter shifts on system performance:
http://www.nousaine.com/pdfs/dynaudio.pdf
http://www.nousaine.com/pdfs/The%20Art%20of%20Breakin.pdf
In both cases the actual total effects on system performance were essentially nil.
- MrEastSide
- offline
- 1,323 Posts. Joined 2/2008
- gtpsuper24
- offline
I'll never understand why people don't just hook their speakers up and enjoy. They'll break in with normal use. And they sound just fine without being broken in. It's not like after a few dozen hours of break-in the speaker, miraculously, sounds 1000 times better. I find it hilarious that some people would leave them playing all day long while they're gone.
People do install there speakers and just enjoy right away. Some companys claim that you need to "break" the woofers in for a certain amount of time. For some its a difference not huge but noticable, others not so much. I've tested it out and there is a difference in the bass especially. The Arx xbl2 woofers are installed "green" and they diffently sound very weak and lacking in the bass. Only when you give them a several hours does the bass improve.
If your one that hooks your speakers up right away and listen then you would become use to the sound. If you demo'd a pair of brand new speakers (never powered) for a few minutes long enough to listen to a favorite song and then let them play while your at work for example and then re listen you'll noticed a difference in sound. Is it 1000000 times better no but its noticable
- losservatore
- offline
- 1,469 Posts. Joined 1/2011
- Bill Fitzmaurice
- online
- N8DOGG
- I like stuff
- offline
- 4,342 Posts. Joined 12/2003
What I always think is funny is that "break in" always seems to be positive.... You never hear of people buying speakers and taking tham back because they liked the sound at first but after they "broke in" they didn't like them anymore. I think that that fact alone is enough to call bunk to most claims of vast sonic differences.
- losservatore
- offline
It can be a marketing strategy, especially when figures in excess of 100 hours get tossed around. As for manufacturing, IME all speakers should be broken in at the factory, not only to give the customer perfect performance right out of the box but also to weed out potential defects. But break in takes time, and time is money, so in most cases it doesn't happen.
I totally agree with you 40 hour is more than sufficient .
Unless all speaker based cone material is tested, there's no way to empirically respond to your above. The general consensus, knowing this is arguable, is fifty to a hundred hours. Currently, I'm breaking in a pair of subwoofer drivers. My goal before first REW measurement sweeps is fifty hours. After that, it's like a bottle of wine, how long do you wait to drink the stuff? I say, break them in over a week or so and then "fer-get-abt-it" as it's either all good or all bad with you being the final arbiter.
It's not efficient. But that's a lab/production based problem, not a consumer based problem.
Break-em-in, don't break-em-in but my opinion, one is not doing either the speakers or their ears justice if they don't take time to break them in "FIRST," before drawing their personal based conclusions.
The longer story, everybody knows they need to break in a new pair of shoes, a bottle of wine needs to age and an engine has a break-in period. Why? Because in the beginning, the material is stiff and unresponsive to movement. Some how, I guess doing so and believing speakers don't need to be broken-in, makes them feel all warm and fuzzy inside. Folks want to believe that speaker based material is immune to this behavior. Why? I guess it's because they're afraid of the truth or it's because they want to believe they're sophisticated like the gurus and above this type of "MYTH." "Everything," from tires to leather is stiff when it's new but somehow, magically, speakers and headphones are not.
In the end, my recommendation, do one's speakers an injustice and don't take a week of break-in time to give them a chance to loosen up. How ridiculous to think one's speakers need to loosen up. After all, they're your speakers and you plan to have them what.......only til the wheels fall off.
Edited by BeeMan458 - 1/20/13 at 2:45am
- arnyk
- Arnold B. Krueger
- offline
IME it may have started out as a dealer strategy called the "30 day in-home trial". After 30 days most people adapt to changes.
The thing that changes the most after you install new speakers is you. Of course people have no way to attach meters to their heads to register the changes, but books like "This Is Your Brain On Music" explain the nuts and bolts of how our brains are programmed and reprogrammed by themselves to perceive pleasure. A new object has no track record of providing pleasure, which is one of the requirements for perceiving pleasure. So, how does a device build up a track record of providing pleasure? For sure it has to stay in service for a number of days to obtain that characteristic as far as the listener goes.
You can figure it out by inference. If you look at the only two articles I can find about measured changes in overall speaker performance during break in, you quickly reach the conclusion that the speakers don't change that much.
If you look at the earnest opinions about how people's perceptions of their new speakers changed in the days following their installation, it is clear that something changed.
There are only four major components to the system - the recordings, the speakers, the room, and the listener. If you study what people actually write, one of the things that may change right after people get new speakers is the recordings they listen to. Or not.
Based on the actual measurements which will probably become more common since more people are doing their own acoustical measurements at home, the speakers change hardly at all.
The room doesn't change itself.
That leaves the listener who we already know to be a very fluid and adaptable creature called a human being.
Go figure!
- Zen Traveler
- offline
- 2,898 Posts. Joined 2/2005
- CDLehner
- Muisc Lover/Gear Enthusiast
- offline
- 8,178 Posts. Joined 8/2006
- Location: Dark Side of the Moon-Right Side of the Bay, MD
Wow; when I saw this topic posted, I thought...that's flame-bait, if ever I saw it, lol. But it seems to be pretty civil so far.
It's a tough subject for me; one I'm really on the fence about. I put it in the "it can't hurt" category; it can't hurt...just in case it allows the new speakers to sound their best...for me to run some music, 24/7 for a number of hours. But I agree; anyone who's listening during that time...has a far more likely chance, that their ears are changing than their speakers. I usually take a quick listen...as I'm human; then just run different program material...give it some decent volume when I can (to me, it's like stretching before a workout; you don't want to push too hard too fast...but you need to get the "muscles" moving), and let things run for a certain number of hours before I'll sit down to do any critical listening. To me...about a week, or 5-7 x ~20 hours a day, ought to be enough for just about any speaker.
Over the past 6 years, I've owned 4 pairs of Dynaudio monitors. Dyns are known to notoriously need a lot of break-in. I've heard some speakers...like the C1; might even pay dividends as things exceed 200 hours or so. I've even heard Dyn guys say...if you're listening during that time; you might even hear them open-up, then close-off...then open-up again, during that long break-in. IDK about all that. It's fine if that's someone's experience; and I will say that I think Dyn makes excellent drivers. I think Dyn's small, 6.5" drivers make pretty good bass for their size. If that means, they are built with very tight polymers...that are made to stretch, and really extend the excursion over time; I guess the whole break-in thing makes sense. As I said; I'm on the fence, but I don't really think it matters. There's no right or wrong here; no one ever got hurt by believing in break-in.
I find the psychology much more fascinating; and agree with the above assertion from Arny 100%. I'm an audiophile, that listens to many genres; much of it, very un-audiophile. Lo-fi, alt, noise-core (or whatever you'd label bands like Swans, GY!BE, Melvins, etc). But when I get new speakers...I tend to break out the good stuff, AQ-wise. You know: Alison Krauss, Diana Krall; all the audiophile darlings. Don't get me wrong; I'll listen to some other genres as well (like Lauryn Hill's The Miseducation Of...is a demo favorite). But, of course...I'm searching through my collection for the good-sounding stuff. Who wants to size their new speakers up, listening to lo-fi sh*t...even if it's what you might listen to otherwise. But...after the honeymoon, I need to force myself to break-out the day-in/day-out stuff. In addition to knowing what speakers sound like at their best...it's equally important, IMO, to know what they'll sound like at their worst.
In fact, it was this disparity...that lead to me dropping a very good speaker; in the Dynaudio Special 25. Fed the good stuff...the 25 can really shine. Really big bass, for its size (at least it sounded that way to me; let's not get into a measurements war here); good sizzle, when you wanted it. It was probably the best Rock "audiophile" speaker I've ever heard. You know...if you're the type of 'phile that needs to crank the Zep, Floyd, Heads, et al; when you're done with Alison and Diana. However...man was it revealing; read: sounded like sh*t, when fed the "bad" stuff. The 25 defenders say you have to really system match, which is cool; and then, really shape your room around it. While I'm fine with the idea that room treatment pays big dividends...I don't feel like a room should have to correct a speaker. Enhance, sure; but if you have to treat your room a lot, just to keep speakers from sounding like crap...that's the tail wagging the dog IMO.
Anyway, that's my 3-cents (and for the record...I'm certainly not bashing Special 25s. Great speakers; just not right for everyone, all systems, and all tastes. And again...all I'm saying is, they don't handle less than stellar audio as well as some. For many, that won't even be an issue; and for others...they want revealing. Warts and all). Good topic...and you guys are doing a good job keeping it on-track.
- how long is a typical "break-in period" for speakers?
AVS Top Picks
Recent Discussions
- › OFFICIAL Samsung Smart TV "Evolution Kit" Thread 15 seconds ago
- › Microsoft fires the first shot in the "NEXT" generation.... 18 seconds ago
- › Your favorite pro amps for powering L/C/R mains? 32 seconds ago
- › Official 2013 Sony R550A series TVs (KDL-xxR550A) --- 50", 60", and... 46 seconds ago
- › /// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ 1 minute ago
- › F8500.. OR .. ZT60 ????? 1 minute ago
- › Pioneer Elite VSX-84TXSi blinking HDMI light... 1 minute ago
- › Official Sony VPL-HW50ES Owners Thread 1 minute ago
- › ***The Official Ascend Acoustics Sierra Thread*** 2 minutes ago
- › Star Trek: Into Darkness in Dolby Atmos 2 minutes ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
