AVS › AVS Forum › Audio › DIY Speakers and Subs › VALUE FOR MONEY AMPLIFIER FOR REAUDIO XXX 18
post #1 of 8
which is the most value for money amplifier for sealed re audio xxx 18 after lab gruppen fp 14000 clone?
my goal is to reach with high spl <20hz.
i am between crown xls 5000 and nova x 6000.
what do you think?
can you propose me something else?
thank you in advance
Michael
post #2 of 8
Are they sealed? What size enclosure? I believe these want more than the clone can give in a relatively small sealed box. Maybe the 5000kw cerwin vega?
post #3 of 8
it is 9 cu ft sealed.
post #4 of 8
post #5 of 8
Originally Posted by subyguy View Post
CV has teamed up with Dr Emmett to come up with a reliable way to power the flux capacitor.
post #6 of 8
Woah. Maybe I over rated that wattage a bit. Lol
post #7 of 8
These are all proven top-shelf amps of a "similar" build-quality (that ALSO come with warranties)... as least as similar as one could get from a different company! !
In no particular order:
A MA-5050 or QSC-5050, PL380 or PLX3602, or a Crest 9200 or CC5500, or nu3000DSP, crown XTI6002.
I wouldn't be personally confident it comparing it to anything less than a top-shelf amp, as the clones are no slouch.
There is also many other china-based switcher amps in existance. How they compare? God only knows.
An actual closer comparisons would be either a: PS K10 or Crown iT8000 or a few heavy-horses with 900X or 1000X in their names. None are cheap/cheaper so. wink.gif
Edited by BassThatHz - 1/18/13 at 10:37am
post #8 of 8
Having had two sealed RE's on a clone, they take a lot to get moving. if you are wanting them to be purely for sub20hz content you are in good shape, and some of the suggested amps will work fine. I will say though, the LG 14k is killer, and the RE's take every bit of power it throws out, and still could ask for more.
