AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Russound ABUS KP2 power but no sound
post #1 of 2
Have a basic single source, 4 room setup. (Hd4 + 4 kp2 keypads). And 3 of the 4 work.
The one that doesn't work has power (via indicator light). Is set to single source. But doesn't appear to power on.
6 year old system in a pre-wired home. Just stopped working for no apparent reason.
Thanks a bunch for your help!
post #2 of 2
Swap the keypads or swap the wiring at the hub to see if it's the keypad or the hub. These pieces show up on eBay often...
Jeff
  Back to Forum: Home A/V Distribution
