It's been a while, but I have a new project to undertake. Currently starting from scratch in a house with no prewired HT connections. Room is roughly 27'Lx24'W with a ~14' vaulted ceiling with large beam running the length of the room. There is a closet at the back of the room behind the couches which has electrical to it which I could use as a media cabinet. I have a couple of questions:
1) Due to the long HDMI/speaker cable runs to the front of the room from the media closet, would it be better to just relocated the AVR to the front of the room on a tv stand/console? The cable runs would be about 50ft long in order to run up to the overhead beam and then back down to the front/center speakers, TV(HDMI), and a subwoofer (RCA). The rear surround channels would be slightly shorter speaker wire runs due to them being closer to the media closet.
2) The room is currently stone/brick on the fireplace-side and loveseat-side of the room, with Mexican tile floor. Paired with the vaulted ceiling makes the room reverberate quite a bit. Will likely be putting down carpet, but is there any concern with speaker placement other than how I have shown below? Surrounds will likely be bipole/dipole with something like Paradigm Monitor 7 or 9's for the front 3. AVR will likely be something like a Pioneer SC-1222-K.
Any suggestions on layout? Would love to keep the AVR in the media closet with the internet router, etc, but if the long wire runs are going to compromise the audio significantly, I can move it up front. I appreciate any help as I'm pretty much a novice at HT theory.
