I'd say both those conjectures are incorrect. To visualize how a wave pressurizes a room with no lag, blow into a straw, with your hand blocking the open end. There is no lag between when you apply pressure at one end and feel it at the other; that's a basic principle of fluid dynamics. As for the speed of sound increase, I'd say that's someone trying to explain a measured cabin gain while not understanding the mechanics behind it. Geddes would have a field day with him. Originally Posted by LTD02
"Additionally it should be noted that for the first 18miliseconds or so, it is physically impossible to pressurize a room (at any frequency) because the speed of sound (although fast) is not instant, it typically takes 36 to 50ms to start taking affect, up to a max of about 1/4 of a second. A trivial fact, but I just thought I'd state it.
There is a special-case to that where that is not true, and that is in hyper-sonic waves, but that's a totally unrelated topic to speakers"
if the room is small relative to the size of the wavelength (i.e. in the pressure vessel zone where the long dim. <1/2 lambda) the speed of sound increases dramatically. this came up when a guy tried to create a double bass array, but it didn't work as expected. then i read about this effect from some physics professors in europe. i don't think i have the reference handy. a trivial fact, but interesting none the less.
Edited by Bill Fitzmaurice - 1/28/13 at 2:43pm
I'm trying for a simple approach, this is my first project
