I decided to start a new thread due to the very helpful advise from a number of you. I have quickly bagged the idea of doing an open theater in my new recreation room which will be about 30x45'. In the image below, the home theater is 21'x16'. The space has cathedral ceilings but the HT will have a 9 foot ceiling. (The spiral staircase in the image will lead to a small loft situated above the theater...mainly to be used by the kids for sleep overs and such). The black rectangle on the wall by the pool table represents the HDTV suggestion to simply hang a monitor out in the play area instead of having the more open theater.
This is my very first go-around with any kind of 3D design. Obviously, things are a little sketchy and I used what components I could to fill in the space. I made this using the Google SketchUP.
Other thoughts: I have not added windows in the gaming area so use your imagination. The cathedral ceiling will employ exposed wood beams and pine. Hardwood in the gaming area with wood on the walls up to a chair-rail height and then paint on the rest of the walls. We are going for a lodge-type look. I live on a small farm and will have some old farm stuff like saddles, tools, etc on the exposed wooden cross beams. It should look pretty nice I would think.
So, any thoughts on the general design? Any specific thoughts on the theater area? Oh, yeah, one more thing. Upon entering the theater, that floor will be flush with the gaming room floor. It will then step down about 9 inches. I thought that would be pretty cool instead of having to step up.
Thanks for the help.
D
D
the idea is to keep the ambient noise in the room as low as possible so the audio is not competing with it.
