I have an over-the-mantle mounted TV. The speakers flank the fireplace with the receiver to the right side. I HAD run my TV power and HDMI cable through the wall, but long story short, I'll be re-fishing them both through.
My question is -- any recommendations for hiding my left channel speaker cable? I'd really hate to bore a hole into the floor or cut through studs for ONE speaker wire. I COULD potentially have it go through the floor where my rear speaker cables run (assuming the hole can fit another 16 gauge speaker wire through it), take out the drop ceiling panels in my basement and then bore back up and have it exit on the left side of the fire place somewhere...but again, that would involve tearing up baseboards, boring holes in the wall and putting some kind of cable "outlet" panel.
So I'm thinking the easiest and cheapest way -- by far -- is just to keep the speaker wire OUTSIDE of the walls/floors. Is there a good way to hide it? i.e. a moldable plastic "runner" that I can flex to the bottom of our fireplace? (PS -- I can get rid of the "bead board" in front of the fireplace. We had it there when our daughter was young so she didn't get in it). There is also a good six or eight inch piece of tile at the base of the fireplace, so the cable and/or "cable hideaway" wouldn't be right up against any super hot surface.
