AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Connecting laptop and FM reception non-existent
post #1 of 5
Dear AVS Supporters,
I have a Pioneer AVSX-52 receiver and was wanting to know how to connect a laptop to the receiver.
Do I use the front HDMI 3 or USB input or do I have to connect it to the back?
Also, I get no FM reception, do I need an antennae ?
Thank You in advance for any information you can provide.
CobraMaster
post #2 of 5
Any HDMI input (front or back) should work and yes to the FM antenna if the unit isn't picking up any stations without one.
post #3 of 5
jdsmoothie,
Thank you, appreciate the information.
Only have USB and ethernet on laptop so should probably pick up a cable that has USB on one end and HDMI if there is such a thing.
Not really that tech oriented.
I did a Google search and there are tech support online before I found this site. They wanted $28 plus deposit. Then I found this site. Sure is nice to have forums that will answer pretty simple questions no charge.
Have a great one and again appreciate it.
CobraMaster
DFW, TX
post #4 of 5
Originally Posted by CobraMaster View Post
jdsmoothie,
CobraMaster
DFW, TX
A USB to HDMI cable would not have sufficient bandwidth to be useful.
post #5 of 5
jdsmoothie,
CobraMaster
DFW, TX
Yes, an adapter should work just fine. Are you wanting to pass video and audio as the audio may be limited to stereo only?
