AVS › AVS Forum › Display Devices › Rear Projection Units › Good old optoma hd70 dead?
post #1 of 3
Greetings all,i have owned this pj for about 6yrs maybe more,bought it new.Recently it has developed some issues,first thing is that it wont turn on,it tries to power up about 3 or 4 times but no picture.It then turns on the orange bulb warning lamp solid and the green power lamp solid.I could get by this issue a few times by unpugging the power cord and then plugging it back in,then it would power up with picture fine.Well finally this workaround didnt work anymore so i figured the bulb finally went,so i replaced it with a cheap aftermarket bulb and it fired up ok but only lasted 15 min before it shut down with no picture.Found out bulb was blown! So got my money refunded for that bulb and purchased what i think was a factory bulb and pj worked fine for two days and wont fire up ,it tries then shuts off with orange lamp warning bulb lit solid and green power lamp lit solid.So did the bulb blow again or is there some other issue here thats telling me this pj is time to retire.P.S I also replaced the color wheel with a factory replacement from optoma when i changed the first bulb,has less than 40 hrs on it.Also cleaned the inside of the pj very carefully,wasnt that dirty surprisingly.
So should i retire this thing and move on?
post #2 of 3
That's a front projector, this is the rear-projection tv section. Go here: http://www.avsforum.com/f/68/digital-projectors-under-3-000-usd-msrp
post #3 of 3
Whoops Ok is it possible to move this to the correct area?
  Back to Forum: Rear Projection Units
