AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Just bought my first plasma
post #1 of 9
I bought a Panasonic 50gt50 and so far love it. I am a plasma newbie so I don't know much with them. Any suggestions on what to do in the first 100hrs so I properly set the tv up. Also when should I calibrate it? What should i use? Any websites? Also any do's and donts would be great. Thank for the help.
post #2 of 9
So watching Netflix through the tv app notices my pic choices become limited. Also I seem to have an annoying flicker going on every min or so. Any help
post #3 of 9
Just use a different device if you have it for netflix.
post #4 of 9
TV shouldn't be flickering. Can you explain a little more?
post #5 of 9
It's only flickering during Netflix playback?
post #6 of 9
Using the tv Netflix app video is set to cinema with motion smooth. set to weak. The screen will flicker or flash like just a quick flicker to black. It's not a constant flicker just seems to happen few times a minute. Trying to see if there is a patern
post #7 of 9
I use my Wii U for Netflix no problems on my VT50 plasma.
post #8 of 9
Quick update took jays advice started to watch movie on ps3 Netflix and don't have the problem. Also all my pic setting are available
post #9 of 9
That is a known Viera Netflix issue. The tv flickers when changing resolution.
This should be helpful:
http://www.avsforum.com/t/1403635/official-panasonic-gt50-series-discussion-thread-no-street-price-talk/5640#post_22853020
Edited by Bond 007 - 1/19/13 at 7:59pm
