AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Repair Poll
Plasma Repair Poll
Poll Results: Has your plasma been or needed to be repaired
This is a multiple choice poll
  • 7% (2)
    LG - Has never needed to be repaired
  • 46% (12)
    Panasonic - Has never needed to be repaired
  • 19% (5)
    Samsung - Has never needed to be repaired
  • 7% (2)
    LG - Has been or needed to be repaired
  • 23% (6)
    Panasonic - Has been or needed to be repaired
  • 15% (4)
    Samsun - Has been or needed to be repaired
26 Total Votes
post #1 of 5
I have read the consumer reports numbers, but was curious to do my own informal poll. I currently own a Samsung that has been repaired once and now out of warranty needs to be repaired again (though I won't do it). If your plasma is defective and out of warranty please check needed to be repaired even if you have NO intention of repairing it. If own multiple plasmas you can check multiple boxes. I am curious about how Plasmas have held up in general and which brand seems to be less prone to repair.
*I missed a G on the last line for Samsung, but can't edit the poll to fix it*
post #2 of 5
I had my Samsung serviced twice under warranty, but it turns out that like a lot of new plasma owners, I simply failed to understand how plasmas work and what I should expect. Nothing was wrong with my set, it turns out tongue.gif
post #3 of 5
Have a repair tech coming on Wednesday to see if he can quiet down the buzz on my 55" Panny UT50. Just got it a couple weeks ago and it's pretty loud on bright scenes. It has an April build date, so likely doesn't have the newer screws with lock washers. So I'm hoping it's a simple fix of replacing/tightening screws like some others have posted.
post #4 of 5
post #5 of 5
Repair vs Owner rates so far are
50% for LG
35.3% for Panasonic
37.5% for Samsung
