With a toddler running around the house - I had to enclose all the AV gear. We had a local furniture shop make a cabinet to spec. When I put all the equipment in - the PS3 in particular started to run hot - it would take all of ten minutes for the fan to go into full speed.
So I went about making modifications to cool the cabinet. I cut vents into the top region of each shelf and added a 24cfm 80mm fan to each shelf to push cool air in. My hole saw was not big enough to completely expose the fan - but it seems like I cut enough out to make it work.
With everything put back together the there is still to much heat in the unit. Looking for suggestions or next steps. Here were my inttial thoughts - curious to see what others think.
1. Cut out rest of material around fan intake area.
2. Add exhaust fan (already have three fans on the cabinet at 12v and they are audible)
3. Cut more material in the cabinet back for additional circulation
Any other suggestions or ideas??
Derek.-
Derek.-
