AVS › AVS Forum › Video Components › Home Theater Computers › Fast Forward / Rewind in WMC
post #1 of 7
Hi,
I know there are quite a few older posts on this subject, but I have not seen anything recently.
I wanted to know the options for enabling "true" FF and RW capabilities for mkv files...not skipping forward and backward and using the number keys.
Currently I use media browser in wmc7, and FF/RW does not work for mkv (why does it work for video_TS though??)
Does MPC-HC allow for true FF/RW? Does XBMC? are there any other 3rd party programs/solutions out there?
thanks for the help,
Chuga
post #2 of 7
Media Control Plugin will allow proper FF/RW when using Media Center
THIS POST on my forum explains how to set it up.
Windows 8 is also supported.
post #3 of 7
Does that work with MPC-HC or only with the Media Center Player? I'd rather have 23.976 fps over a 3-2 pull down scheme and put up with the skip rather than true >> and << but if I can have both that would be fantastic.
post #4 of 7
Media Control is a Media Center plugin based on FFDshow and created by one of the FFDshow developers. The developer has since abandonned the project but a user on my forum has taken up the project.
post #5 of 7
I just looked at the screen shots and it looks as if 23.976 fps is possible but it isn't using MadVR but rather EVR (CP)?
Thanks..
post #6 of 7
Where is the source code for this located?
I guess this is it:
http://mediacontrolmce.sourceforge.net/
post #7 of 7
thanks..I'll give this a try and see how it goes.
