Hey all,
I recently decided to Bi-Amp my front speakers with my Yamaha RX-V667. I've hooked up everything with banana plugs to the second posts on my fronts and into the correct ports on my receiver. However, now when I try setting it up or running YPAO or anything. The receiver shuts off and when I turn it back on it says Check Speaker Wires. I'm not sure what the issue could be it only happens when I set it to 5 Ch Bi-Amp, not when it's on 7 Ch.
What would you all recommend I do? I'd really like to Bi-Amp the speakers, even though I know it won't have a ton of extra effect.
Thanks!!
Thanks!!
